Virtual thermostat : base temperature and current setting
  • Hello,
    I'm setting up my first vitual thermostat with a H&T and a 1 plus PM, both are connected to Shelly Cloud.
    I can't quite understand the difference between the those concepts
    - "base temperature" : when does it apply, outside of any schedule ?
    - "scheduled temperature" : this is the one I understand: apply this temperature within the schedule
    - current setting: this one I absolutely don't get. In the UI, I can adjust this temperature with up and down arrow and the relay reacts immediately. This seems like an override to the current base/scheduled but then : how do I remove this override, how to return to applying base/scheduled instead of "current setting".
    I'm quite lost and could not find documentation on this.
    Thanks
    Jean-yves
