OPEN/CLOSE status on uni
  • Hello, I'm trying to solve how to make it work. I use uni 7 and 8 contact for magnetic switch, but in app no actions.
    I'm trying to make it like on shelly1 with addon we can see Garage gates open or closed.
    Maybe someone can help me ?
    Thank you.
  • If you are using DC you must connect one wire to positiv (from power-supply) and the other wire to 7 / 8.
    if yourself using AC you can use SENS Vcc pin (4) as power for the magnetic switches.
    Edit: you can use SENS Vcc pin (4) also on DC
  • Hello folks!
    I have the same need! Because I am not a pro user could you provide a wiring diagram of this installation or a photograph? Whatever is easy.
    Thank you in advance!
