How to displaying current status of sensor BLU Door Window on module Shelly Plus 1
Hinweis für Entwickler
  • Hello,
    have question about sensor BLU Door Window and module Shelly Plus 1. Use sensor for garage door and module for steering.
    I did try to find on forum if there is already any solution how can be displayed status of senzor on module.
    I try to add "Add-on sensors" in peripherals but dont know how to connect module with BLU sensor. Now I have some sensor which show status but it is not the BLU sensor. On picture below, there is clearyl it is clearly seen how on the module unknown/unconfigured sensor is shown as open, while the BLU sensor is closed.
    So since there is no option to connect over settisng I beleive this is not the solution.
    Still I wish to make automation to see status of BLU Door Window sensor on module Plus 1 (red square on picture) .
    I know that I can create scene for that but I really wish to connect sensor with module in a way so I can always see status of BLU sensor directly on module.
    I'm new in this things so thanks in advance for any tips and help.
    Regards, Onilko
  • Hello,
    - So you're utilizing your Blu Door Window to keep track of the status of your garage door?
    - And now you wish to directly view the status of the Blu Door Window within your app, integrated into the graphic or icon of your Shelly Plus 1?
    First and foremost, I'm not sure how the hell you managed to configure a garage icon with a status indicator on a Plus 1. In fact, a Plus 1 is typically not intended to control a garage door, as it can only toggle on or off. It would be great if you could also send us some additional pictures, such as pictures of your Shelly Plus1 app settings and some pictures of the Plus 1 mounted next to the garage door.
    It appears that you might be using some kind of translation tool. Please also provide your response in the original language, so that I can pass the original text through Chat GPT, which doing a much better job at translation, compared to most online tools.
  • Hi folks,
    I’m looking for the same solution.
    Using the new Shelly blu d/w to show the status of the garage like in the picture from onilko.
    Did someone already configured this?
    Regards
    Tom
