Does MQTT work already
  • I use MQTT a lot with other Shelly devices. But so far i could not get the wall display working with my MQTT Broker. I hope there is soon an update coming. Hopefully together with the option to use the wally display as a thermostate/sensor.
  • MQTT seems to have a bug.
    I've reportet to Shelly (BG).
    Can you plese send me a screenshot of your mqtt-settings via PN or posting here? If we give more informations, there is a good chance for fixing soon.
    Debug.log would be helpful too.
  • Dou you have a Debug-Log-File please? Or / and a screenshot of the MQTT-Settings?
    I think, same issue.
  • In the log file I get the MQTT error:
    [2023-09-14 14:19:05.278] [MQTT:DISCONNECT]: Disconnected
    [2023-09-14 14:19:05.280] MQTT disconnected!
    [2023-09-14 14:19:05.299] [MQTT:CONNECT]: Connection failed: CONNECT failed as CONNACK contained an Error Code: UNSUPPORTED_PROTOCOL_VERSION.
    [2023-09-14 14:19:05.301] MQTT connection failed: CONNECT failed as CONNACK contained an Error Code: UNSUPPORTED_PROTOCOL_VERSION.
    If you the further google for UNSUPPORTED_PROTOCOL_VERSION you will find that your broker ist using MQTT 3, which has a 2 byte CONNACK versa the MQTT 5 having a 3 byte CONNACK. Now the bad thing is, that the wall display seems to be the first and only shelly device not supporting MQTT 3.
    Let's hope they will add MQTT 3 support, since this is a very wide spreaded version. There is probably not a good reason having on device which is different than all the others.
    When you use a MQTT 5 broker everything seems to work (eg. test.mosquitto.org). However i found missing state messages and event messages
