Hinweis für Entwickler
  • I am having trouble parsing the output from a Shelly 1PM.
    The script is currently:
    Shelly.call(
        "HTTP.GET",
        {"url": "http://192.168.20.23/status"},
        function (response) {
            let status = JSON.stringify(response.inputs.0.input);
            print(status);
        null
    The output comes back with an error. I am trying get the status of the input either a 0 or 1.
    Thanks
  • Hello,
    It should look like this for a Remote Shelly input call:
    But that code above was without proper error handling, so if you want to do it properly you should do it like this:
    If you just want to get your local Shelly's input state, you should use Shelly.getComponentStatus() or an event handler, for example:
    print('The Input 0 State is ---> _[', Shelly.getComponentStatus('input',0).state, ']_');
    7 Mal editiert, zuletzt von _[Deleted]_ (15. September 2023 um 15:44)
