Shelly dimmer and compatible PIR sensor + switch
  • Hi all,
    I bought a Shelly Dimmer with the goal to add an PIR sensor (eg. connected to i1) and a switch (eg. connected to i2).
    Nevertheless, the most PIR motion sensors have a delay time of minimal 10s (10s high signal).
    I experience now that this isn't working with the Shelly Dimmer because of the 10s time delay.
    And if the sensor works, then I see a problem to control the light by the switch.
    I think I need a motion sensor, preferred working on 220/230v, that gives only one pulse instead of a longer time a high signal. But can't find these.
    Can someone help?
