Looking for proven setups with CCT downlights or similar
  • Hi all,
    I'm new to the forum and I'm looking for some help. I'm busy with a renovation and want to change the whole lighting system in the house. Everything will be run through HA.
    The problem I'm having is that I would like to have downlights in the living area and other areas which I can both dim and depending on the need or time of day, change the color temp of. I don't want/need RGBW lights, just white lights with a range of approx. 2.500K to somewhere of 5.500K.
    I'm pretty sure I should be able to do this with the RGBW2, but I fail completely where it comes to the drivers and LED lights I need to install.
    Can anyone point me in the right direction for a driver and LED combination that should work without problems with the RGBW2??? Are there lists of proven combinations somewhere? I rather not install some obscure chinese drivers or LED's either, as I don't like to replace stuff within the first couple of years.
    Thanks!!!
    PS: shutters and garage door will be run through a couple of Shelly Pro Dual's, underfloor heating partially controlled by five DS18B20 through a Plus Add-On, etc. etc.
