Toggle switch on a bluetooth connection
Hinweis für Entwickler
  • Hi, totally new here with Shelly.
    Had an idea to toggle switch on a smartphone bluetooth connection to the shelly, but the more time is spend searching for anything similar, the more i think that is not going to work. Or is it ? Idea is to use shelly in a garage, where when i get into the proximity of bluetooth connection to my phone, the internal switch gets toggled and i get automatic light actuation in there. Is this anyway possible at all without buying shelly blu BT button ? ?(
  • I have a similar scenario but with lights. Whenever I arrive with the car near the garage, the lights internal and external lights of the garage turn on. I have basically enabled the scanner for bluetooth with a script and whenever it "sees" the name of my device, it turns on the lights
