Help with h programming Analog AddOn
  • Hi,
    I’m new to programming the Shelly’s and need a jump start. I have a Shelly Plus 1 and the analog add on. Connected to the analog add on is a humidity sensors. I can see the analog input change its value based on measured humidity.
    Now, I like the Shelly Plus 1 relay output to change its state based on the measured humidity. Let’s say >50% relay output on, <50% relay output off.
    I assume this should be possible with web hooks but I have no idea how. Can someone help me?
