Hi,
What power supply can I use to connect the Shelly? A power supply for Led?
Best regard
Hi,
Best regard
power-supply (LED-Driver) with 12 VDC ±10% with more than 500mAh is sufficient
This product is ok?
Looks good. Provided you only want to power the Shelly. What do you want to switch with I/O?
I recover the state of a portal with his dry contact. I have troubles with the wifi of the shelly for open the portal with telecommand on 220v
