Home Assistant: Shelly BLU Door/Window not updating
  • I replaced the Shelly Door/Window 2 (Wifi) with the BLU Door/Window (Bluetooth only) for my garage doors. I integrated them in Home Assistant via BTHome.
    It often does not update in Home Assistant! In Shelly App it shows it status correctly tho.
    Is there anything I can do? Are there some settings (in Shelly or BTHome/Home Assistant)?
    I remember that for the previous Door/Window 2 CoIoT must have been enabled and for Gen. 2 devices outbound websocket. Any similar tricks for the BLU Door/Window?
    Somehow I have no luck with my garage doors Shelly sensors. None of them work accurately.
    Thanks for any hints!
  • I assume first of all that you use the internal integration in HomeAssistant for the Shellys?
    On which Plus/Pro Shellys have you activated the BT Scan in HomeAssistant and do the scripts also run on the Plus/Pro?
    Have you restarted them?
    Einmal editiert, zuletzt von apreick (17. August 2023 um 10:45)
  • I'm having exactly the same problem. Status shows fine in the Shelly app but it's not updating in Home Assistant. And yes I've got bluetooth set to passive and have restarted the Shelly Plus Plug UK it's connected through.
    Interestingly, illuminance and rotation DO, sometimes, update in Home Assistant, so there is some connection, but the OPEN/CLOSED status, the main one I want, does not ever seem to!
    Any suggestions would be much appreciated.
    2 Mal editiert, zuletzt von RjwBn2 (18. August 2023 um 11:25)
  • I do not have a SHELLY BLU DOOR/WINDOW
    But if the status is shown in the Shelly Smart Control App and all other sensors are transmitted in HomeAssistant, then I am guessing an error in HomeAssistant.
    Have you guys ever looked here?
    https://community.home-assistant.io
    Or also reported a issue?
    https://www.home-assistant.io/help/reporting_issues/
    Hey,
    I am currently experiencing the same issue. Strange thing is I have 8 BLU D&W Sensors. 7 of them are working just perfectly in HA. only one shows the exact same issue you are describing above not updating the state. I am running HA on RP4 and I heard there are Bluetooth issues with HA Version 10 and higher but I have much more Bluetooth devices just working nice.
    Currently it is only this one BLU Device which is not working properly in HA and same as you have in the Shelly app it shows up perfectly but not in HA.
    Did you find out what the issue was / is or communicated to the HA community already?
    Thanks
