CoIoT update_period can be set to 15 - but still operates at 30sec
  • I can set the update period to 15 sec at reding it in status also show afterwards the 15, but the real intervall stays at 30s.
    I'm using the Home Assistant Integration (via CoIoT). I set the value with http://<IP>/settings?coiot_update_period=15 and it is accepted by listing it afterwards.'
    But looking at the intervall it still is 30 sec, also setting e.b. 60 sec does not have any impact. I want to avoid migration to pure MQTT, loosing the cloud functionality.
    Einmal editiert, zuletzt von Michael Wurzer (23. August 2023 um 19:30) aus folgendem Grund: Nobody around that wants to have data update faster 30 sec? I use the Home Assistant Integration which uses CoIoT and changing the param does not have any impact regardless if higher or lower 30 sec's. Pls help!
