Need delay before excecuting HTTP command
  • I'm using Shelly EM for measuring power to my electrical car. When my car battery is fully loaded I want to switch off the power of my wall outlet. I can do this by implementing command "under power URL" in shelly EM. When car battery is fully loaded the charging system is still using about 2 watt's of energy, so i need to switch off in shelly EM when power consumption is below i.e. 2,1 watt. But when starting up the loading process power consumpion is even below 2 watt for a while,which means that my EM is shutting off power and therefore the charching process does not even start. So, the question is: Is there a command or possibility to activate the HTTP command after a certain time I have started the charging proces, i.e. 30 seconds or so., or just a command to deactivate a HTTP command for a minute after starting the charging process. Another possibilty would be a command that is able to switch off when power is below a certain value for at least a certain time
    Hope somebody has an idea how to solute this issue.
