What is the payload to publish to shelly motion 2 topic shellies/command or shellies/shellymotion2-xxxxxxxxxx/command
Hinweis für Entwickler
  • I am trying to find which topic and what should be the payload to send commands to Shelly motion 2 device such as set sensitivity of motion. Can somebody help me? I tried many ways such as
    {"device": "sensor", "index": 0, "name": "sensitivity", "value": 50}
    sent to
    shellies/command
    and
    "sensitivity": <desired_sensitivity_value>
    To
    But no luck to make it work :(
