Having extreme problems connecting the app to it
Wow, so much informations. ![]()
For help. we need some more informations, sorry.
| Actuator | problem / error pattern |
Yeh sorry for lack of info.
From the 192.168.33.1 I log on and set the Wi-Fi, when I go to the app and try to add it. I find it but it then can’t connect to Wi-Fi. Tried adding it vie Bluetooth but the same. Tried reset and all of the above again but no luck. Do I have to disable AP after I set Wi-Fi
You must not.
I think your problem is the sleep-mode. Try with USB-power, not with battery.
Is it your first shelly in your network?
