Swimming pool pump and light with Shelly
  • Hello Everybody,
    I just installed my electric box for my new swimming pool : Der Inhalt kann nicht angezeigt werden, da Sie keine Berechtigung haben, diesen Inhalt zu sehen.
    NOw I would like to add 2 Shelly.
    1 Shelly Plus 1 for the light.
    1Shelly Plus 1 for the pump.
    I would like to keep my mechanical timer as well as the AUTO/OFF/MANUAL buttons. Just in case.
    Do you think it will work with this diagram ?
    For exemple :
    • The OFF button keep the possibility to switch off the mechanical timer AND the Shelly. It's seem to be important for maintenance (cleaning the pump, active the 6 ways valves, etc...)
    • The AUTO Button will be the usual utilisation, working with Shelly App and any voice assistant.
    • The ON button will activate the pump anywhat appens. Even if the shelly's program is settings on Hold. Idem with the mechanical timer ?
    Si ce n’est pas le cas je dois ajouter quelque chose au SW du Shelly ? Vous en parlez à de nombreuses reprises. Du coup dois-je ajouter quelque-chose à mon schéma ?
    Pour l’utilisation du bouton de lumière aussi ?
    Base on my wiring diagram and on this utility, can you tell me if I need to add something at my SW wiring please ?
    For the light too ?
    2 Mal editiert, zuletzt von FiiMeRoNeR (3. August 2023 um 23:30)
