MQTT is not publishing single topics, but Object that Node-RED/InfluxDB can't parse?
  • I want to use MQTT to visualize the power consumption of a device plugged into my Shelly Plus Plug S. But it appears that it's publishing only a single MQTT topic containing a bunch of information. The topics name is shellyplug/status/switch:0 and contains the following:
    {"id":0, "source":"init", "output":true, "apower":26.2, "voltage":232.1, "current":0.179, "aenergy":{"total":3314.509,"by_minute":[436.678,435.823,438.814],"minute_ts":1690747019},"temperature":{"tC":33.5, "tF":92.3}}
    Unfortunately Node-Red and InfluxDB can't parse this information. Node-Red is giving me the following error:
    Error: A 400 Bad Request error occurred: {"error":"unable to parse 'apower aenergy=[object Object],apower=26,current=0.177,id=0,output=true,source=\"init\",temperature=[object Object],voltage=232.3': invalid boolean"}
    What am I missing?
  • Another Shelly-type, but perhaps, this helps:
    Gast10
    24. September 2021 um 17:31
    (Sorry, a German thread. )
  • Here for your datapoint:
    MQTTin-Node
    Topic: PlusPlugS/EG/BT-Gateway-shellyplusplugs-3ce90exxxxxx/status/switch:0
    and:
    That's all. :) :thumbup:
  • dataprolet
    1. An MQTT topic is always a single one.
    2. Please describe or show your Node-RED flow!
    Do you use a JSON node after the MQTT in node?
    In a node after such JSON node you can access apower per
    msg.payload.apower
    Alternatively you may use the instruction
    let p = JSON.parse(msg.payload);
    in a function node. After that you can access the wished part, e.g. apower, per
    p.apower
