- Offizieller Beitrag
© 2020 Stefan K. (aka 66er) All rights reserved!
Today I can introduce the integration of the Shelly Duo into the homematic world.
technical requirements:
- compatible with the Homematic systems CCU2, CCU3, Charly, as well as all offshoots such as RaspberryMatic and piVCCU.
- installed addon CUxD
(The knowledge of how to use CUxD, such as creating devices, I assume at this point, otherwise this manual "explodes". Thank you for your understanding.)
The advantages from my point of view:
- all Shelly Duo properties are retained because I operate all actuators and sensors with the original manufacturer firmware
- all future Shelly Duo updates / updates will be available
- Full Shelly app usability parallel to Homematic automation
- Operation as a local solution or via Shelly cloud, additionally Homematic
I have implemented the following functions on the Homematic page:
- Display of the switching status (ON / OFF)
- Online status display
- wattage display
- Brightness and color temperature controllable and update when operated via app
- optional operation only ON - OFF (= connection without dimming functions)
The view of the connection:
(The picture shows a favorite, consisting of a switch and DIM Exec device)
I would like to recommend you, especially beginners, to take a look at this thread before implementing:
Otherwise, as always:
If not yet available, please create a device (28) System Exec! The commands are issued above this. (No entries are made in the CUxD-Exec!)
If necessary, there is an
instruction for creating the CUxD-Exec device.
Have fun and good luck with it.![]()
