How to disable MQTT
  • Hi, I have enabled MQTT on the shelly uni with Firmware v1.13.0-g9aed950/20230503 via the web gui. Now I want to disable MQTT again.
    However, whenever I uncheck the MQTT feature, the SAVE button disappears as well. I don't see a chance to save the new setting. Am I missing something?
    Thanks
  • Try to disable it via Webinterface (via IP in browser). I have the same problem while changing type of switch.
    Hi, thanks for the hint. As far as I know, MQTT is available via the Web-Interface only. For the uni, this feature is not available via the app. The issue reported relates to the Web-Gui.
