Device goes instantly to sleep
  • After few tries (removing and inserting battery and connecting to wifi) I was able to set my WiFi on the Shelly Smoke PLUS. However, I am not able to connect to it's IP. After I insert the battery, red and blue read comes on for a second, than dims and the IP is not responding. When I hold the button for 3 seconds, I hear loud 3 beeps, blue light comes on for a second and I'm connected to the web interface. However, after a second the interface says the device is asleep and I cannot configure anything.
    Also, I didn't find anywhere how to factory reset the device so I'm a bit afraid to return it as is (with the WiFi setup).
  • Bedientaste
    Halten Sie die Bedientaste (B) 3 Sekunden lang gedrückt, um das Gerät zu
    testen.
    Kurz drücken, um einen Alarm abzustellen.
    Drücken Sie 3 Mal kurz, um das Gerät für 2 Minuten in den Setup-Modus zu
    versetzen.
    Zum Zurücksetzen auf Werkseinstellungen 5 Mal kurz drücken. Das Gerät
    bleibt für 2 Minuten im Setup-Modus.
    Control buttonPress and hold for 3 sec to test the Device.Press briefly to silence an alarm.Press briefly 3 times to put the Device in Setup mode for 2 minutes.Press briefly 5 times to factory reset. The Device stays in Setup mode for 2 minutes.
    So steht es in der Anleitung:
    https://shelly-forum.com/filebase/entry…hig/?fileID=423
    https://shelly-forum.com/filebase/entry…hig/?fileid=422
