all shelly devices are reseting after a power failure
  • Since the last updates, after a power failure, all the shells are reset and I have to set them again.
    I have experienced this twice and it wouldn't be a problem if I only had one, but I have to reconfigure 30 devices shelly1, shelly 1pm,shelly plug and shelly 1 plus pm.
    Please check and try to solve this problem.
    Thank you!
    Einmal editiert, zuletzt von Danbv (4. Juli 2023 um 08:17)
  • Which firmware version do you have installed on the devices? Did the devices really reset to factory settings after the power cycling?
  • Hi Danbv ,
    I guess you had at least 5 switching cycles within one minute.
    This is the sequence to reset a Shelly to factory settings!
    To avoid this in the future, you should disable this in the settings.
    elektroman:~#
