Change Input Attached to Output option
Hinweis für Entwickler
  • Hello.
    Is it posible to toggle the option "Attached to Output" option from attached/detached ? Im trying to do a script and that is the only thing im not beeing able to do. Is it possible to be done via sscripts in a Shelly 1PM plus ?
    Thank you so much.
  • Sure. You can use this code for something like that.
