BASIC DIMMING SCRIPT for SHELLY DIMMER2
Hinweis für Entwickler
  • Hi,
    i need some help .
    how to write a basic script for Shelly dimmer2
    event would be something like this:
    turn on light on pushswitch/through app
    check dimmer brightness %
    if "brightness is in range 70% - 95% " 1st long hold-push action to dimm should lower brightness
    if "brigtness is in range 69%-10% " 1st long hold-push action to dimm should increase brightness <-- this is already by default as it always increases brightness no matter the %
    if possible i would also like to to add max brightness 95%
    if possible i would also like to add min brightness to 10%
    Or is there any other way i can create a function like this?
    Looking foward to your reply.
  • Yes, only remote control via a Gen 2 script is possible, so plus or pro, as I said, there are at least 2 scripts for remote control of gen 1 out there. No special Button Events possible only gen1 Events/Aktions that can trigger a gen2 http endpoint, are useable.
    Hi,
    first thank you for your answer.
    This got me a little bit confused. Just to clarifty:
    only gen1 Events/Aktions that can trigger a gen2 http endpoint, are useable <-- this means there are some GEN1 action, that can trigger gen2 endpoint but i need some extra equipment of software for this?
    If i cannot write scripts for GEN1 dimmers, is there a way atleast i could limit max brightness ( this is my main issue, everything esle is just bonus). As in WEBUI i only see limit minimum brightness.
    Could this be solved in Home Assistant software?
