External Switch stopped reporting output
  • Shelly 1 version 20230503-095514/v1.13.0-g9aed950 (latest)
    Appliance Type: General
    Button Type: Detached Switch
    External Switch: Enable external switch add-on
    Flipping the switch turns output ON/OFF
    This was working on two switches, but stopped, not sure if after an update. I use the switch to use Home Assistant to turn on a fan light (but not the actual fan) using the light switch. If I just use the iOS app or look in Home Assistant, I don't see the state changing when I flip the switch, however I do see it in the Web Interface.
    Einmal editiert, zuletzt von pborjas (28. Juni 2023 um 23:43) aus folgendem Grund: Additional information
