Prioritizing temperature interval by Addon over switch ON Shelly modul
Hinweis für Entwickler
  • I'd like to condition turning on Shelly 1PM+ only after fulfilling temperature interval condition by Shelly Addon, i.e. so that the Shelly module cannot be switched on otherwise.
    Is this possible, eventually please advise how?
    Einmal editiert, zuletzt von qwero (28. Juni 2023 um 12:58)
  • qwero 29. Juni 2023 um 14:33
    Hat den Titel des Themas von „Prioritizing temperature interval by Addon to switch ON Shelly modul“ zu „Prioritizing temperature interval by Addon over switch ON Shelly modul“ geändert.
  • Hi,
    what exactly do you mean with ' fulfilling temperature interval condition' ?
    You could set your Shelly in the device settings to be detached from its input and only controlled by a script or action.
  • Hi De kat,
    would you mind to instruct me how to detached my Shelly 1PM+ from its input to control the device just by actions?
    Many THX
    p.s. fulfilling temperature interval condition = actions
    Einmal editiert, zuletzt von qwero (2. Juli 2023 um 23:26)
