Syslog'ing
Hinweis für Entwickler
  • I wonder if there is a way to send syslog messages from a script e.g. to a NAS or other syslog server on the local network. The UDP Debug setting is giving the full Shelly system log and that is much too much. I just want to be able to create selected log entries from various places in my scripts.
    Perhaps the code for a simple function could be added to the Github compilation of example script code? Or perhaps someone has a link to somewhere else I can grab such code/function?
  • No,
    there is only an option to send the full log to XY. This can be set via script, but I recommend just using the Web UI.
