Script for Cover
  • Hello,
    i need to support a particular motor blind (see image attached). I have connect the circuit with myne Shelly PRO 2PM and set it in Cover mode. If i press the Up or Down button it works but the problem is the stop button.
    I'm so tring to implement a script for make it working.
    In this script what i want to do is:
    - store a status of the action that the cover is doing
    - based on the status for stop the blind i have to set the shelly in stop mode and then re-set the output in open or close. This stop the blind.
    The problem is that seems the status variable not store the value 1 or 2.
    this is the log:
    opening
    INPUT: Cover is now opening
    stopped
    INPUT: Cover button stop
    STATUS: Cover to stop:
    0
    undefined
    why the status not take the value?
    Thanks
  • Hello,
    e seems not be the problem. In the script i can reach the line 24 but after that status value is always different from 1 or 2.
    The variable status not keep the value.
    Thanks
  • Looks like you have a three-position switch (locked up, stop, locked down) and in that case you do not need a script. Instead you need to configure (via settings) the input as Switch and not as Button.
