Smart plugs controlled/operated by Shelly 1 behind standard switch
  • Hi there,
    I'm a happy shelly smart plugs user at the office - installed on all our machines to hard-reboot computers which did freeze via Home Assistant + get power consumption and it's proven pretty useful.
    I'd like to get some advice regarding the Shelly 1 Relay for home usage. This should ideally work without the need for Home Assistant/Jeedom boxes, but note that I do have a Philips Hue bridge and Somfy Tahoma boxes, though I'm pretty sure I can manage what I want without these.
    I have a standard (ie not smart) switch in the living room which controls standard light bulbs on the ceiling. I'd like that same switch to also toggle on/off floor-lamps at either ends of the room, which would probably be plugged into shelly smart plugs. I could not find the same setup where a dumb switch, with a shelly 1 relay attached, would trigger on/off other shelly smart-plugs. Does it have to go through scripting - I've seen some examples which could probably be adapted to my use-case - or is there a simpler way within the relay settings to bind the relay state to that of other shelly equipment (the associated plugs)?
    Thanks a lot for getting back.
    Best,
    Jonathan
