Hi all,
First-time poster here.
I have some questions on https://shelly-api-docs.shelly.cloud/gen2/General/Authentication. The documentation says:
When communicating over HTTP, this process must be repeated for each request you send to the device. However, for communication over websocket there is no need to pass through steps 1 and 2 more than once: you need to construct the auth object only once(see more about that below) and then use it for all consecutive requests to that device.
However, I am not sure that is correct. I am using homebridge with the homebridge-shelly-ng plugin and while controlling a Shelly Plus 2PM works right after restarting homebridge, it stops working after about an hour with:
code: 401,
message: '{"auth_type": "digest", "nonce": 1685710700, "nc": 1, "realm": "shellyplus2pm-<id>", "algorithm": "SHA-256"}'
What's interesting here is that the returned nonce is different from the one received during the initial auth, apparently it expires after about an hour. If I re-generate the auth with the new nonce, it works again. As far as I can see neither homebrdige itself nor the plugin (precisely the npm package shellies-ng) close the websocket, so to me it sounds like the documentation contradicts the implementation and re-auth is in fact necessary after some time.
Does anyone have any insights on this?
Thanks in advance!
