Shelly EM3 not connecting to MQTT broker
  • MQTT IP Adresse 192.168.33.2/ Port: 1883 / Username / Password has been configured and saved. Shelly has been rebooted.. Broker on IP 192.168.33.2 is running (mosquito) Firewall is turned off.
    But Shelly EM3 does not connect.
    curl "http://192.168.33.1/settings result of mqtt:
    "mqtt": {"enable":true,"server":"192.168.33.2:1883","user":"admin","id":"shellyem3","reconnect_timeout_max":60.000000,"reconnect_timeout_min":2.000000,"clean_session":true,"keep_alive":60,"max_qos":1,"retain":false,"update_period":30}
    curl "http://192.168.33.1/status result for mqtt:
    "mqtt":{"connected":false}
    Has anybody any idea what to check? Where can i see the connection attemts / failures?
    Didn't see anything when calling curl "http://192.68.33.1/log" (or .../log1)
    Thank you in advance!
  • Tho van Ho 26. Mai 2023 um 11:52
    Hat den Titel des Themas von „Shelly EM3 not connecting with MQTT broker“ zu „Shelly EM3 not connecting to MQTT broker“ geändert.
  • Gast10 22. Dezember 2023 um 06:42
    Hat das Thema aus dem Forum Shelly EM nach Shelly 3EM verschoben.
