Use of Bluetooth
  • Hi. Brand new here.
    Can you use the bluetooth connection to force the relay ON in the case of wifi failing?
    The plan is to use the relay to control a hot water cylinder and I don't want to be left with no power to the heater due to a wifi failure.
  • Hi Mark,
    Bluetooth?: No, I don't think so.
    But you can use the AP from the Shelly (in this case you should set a password, otherwise anyone can connect to your Shelly). Or you add a physical switch to the PLUS 1 PM...
