Ventil voll geöffnet, Temperatur viel zu hoch
    der TRV öffnet das Ventil vollständig, obwohl die Ist-Temperatur höher ist als die Soll-Temperatur. Auch eine Kalibrierung des Ventils ändert das Verhalten nicht. Der Akku ist hinreichend voll.
    Danke
    current_runner
  • {"wifi_sta":{"connected":true
    "ssid":"XXXX"
    "ip":"192.168.178.185"
    "rssi":-65}
    "cloud":{"enabled":true
    "connected":true}
    "mqtt":{"connected":false}
    "time":"23:46"
    "unixtime":1684964772
    "serial":XX
    "has_update":false
    "mac":"XXXXX"
    "cfg_changed_cnt":0
    "actions_stats":{"skipped":0}
    "thermostats":[{"pos":-1.0
    Device is no longer mounted on the radiator, as it is open all the time.
    "target_t":{"enabled":true
    "value":31.0
    The Device is programmed by "Schedule" for 15 °C with two switching times every day. => So there is no known reason for this temperature
    "value_op":8.0
    "units":"C"}
    "tmp":{"value":17.3
    "units":"C"
    "is_valid":true}
    "schedule":true
    "schedule_profile":1
    "boost_minutes":0
    "window_open":false}]
    "calibrated":false
    "bat":{"value":45
    45 % is more than 0 %, so if the minimum level for operation is 60 or 80 %, the bat value has to be resacled to show = at the real value.
    "voltage":3.496}
    Is there a limit available?
    "charger":false
    "update":{"status":"unknown"
    "has_update":false
    "new_version":"20220811-152343/v2.1.8@5afc928c"
    "old_version":"20220811-152343/v2.1.8@5afc928c"
    "beta_version":null}
    "ram_total":97280
    "ram_free":22648
    "fs_size":65536
    "fs_free":59552
    "uptime":276893
    "fw_info":{"device":"XXXX"
    "fw":"20220811-152343/v2.1.8@5afc928c"}
    "ps_mode":0
    "dbg_flags":0}
