Shelly Dimmer 2 with pair of 4 gang switches "1-0-2" for on/off and dimming
  • Hello, I am looking for a way to connect.
    Shelly Dimmer 2 with two (roller blind type) switches that has 3 positions per line: "1-0-2"
    1 - short push turn OFF/ON, long push bright down
    0 - Default state
    2 - short push turn OFF/ON, long push: bright up
    Each switch has two lines, so x2 "1-0-2" per switch.
    Desired:
    Behavior:
    - sw1 and sw2 can OFF/ON (per line)
    - sw1 and sw2 can dim/bright (per line)
    - safe in edge-case scenario (child1 hold dim at sw1 when when another child2 hold dim at sw2)
    Connection (valid?)
    - [ sw1, line1] <-> [Shelly Dimmer2, Line1] <-> [ sw2, line1]
    - [ sw1, line2] <-> [Shelly Dimmer2, Line2] <-> [ sw2, line2]
    Example mechanisms:
    - Haeger / Berker 53503404
    - Gira 014700
    Questions:
    - How can I connect (4 gangs for two lines) switches pair with shelly dimmer 2 and satisfy desired behavior?
    - Is a single dimmer 2 just enough for that?
    - How does the desired wiring look like?
