- Offizieller Beitrag Autor
Hello Homematic Friends,
finally the time comes, the integration of Shelly 3EM in the HomeMatic. The Shelly 3EM was a long time coming!
To integrate the Shelly 3EM into Homematic, you do not need any third-party firmware, that you have to flash.
Below my solution with the original firmware:
techn. Requirements:
- compatible with the Homematic systems CCU2, CCU3, Charly, as well as all offshoots like RaspberryMatic and piVCCU.
- installed add-on CUxD in current version
(The knowledge about the handling CUxD, such as devices create, I assume at this point, otherwise "exploded" this guide Thank you for understanding.)
I implemented the following functions on the Homematic page:
- ON / OFF
- Update of the currently switching state in a freely adjustable interval, regardless of whether the operation is via Homematic or Shelly app or button
- Optional monitoring of the online status (accessibility via WLAN)
- Optional monitoring of currently power (W) per phase
- Optional monitoring of currently voltage (V) per phase
- Optional monitoring of currenty current (A) per phase
- Optional monitoring of currently total consumed Energy (kWh) per phase
- Optional monitoring of currently consumed total Energy (kWh)
I would like to recommend you to take a look at these threads before the implementation:
- Important notes on the Shelly couplings on Homematic
- Actions vs. Status queries in the Shelly couplings
At the appropriate place in the manual, everyone has to decide for themselves which route the switching status monitor wants to use. ![]()
A view to the connection:
Picture 1
Note!
At this point I would like to point out, based on the amount of measurement data, that it is also possible to "sort" the individual electrical quantities in separate CUxD device channels. On / off has no function there!
You only have to make sure that the channels of the "CUxD (40) 16-channel universal control as switch" are assigned accordingly in the system variables and the scripts !!!
The implementation:
(On the description of the creation of the CUxD devices I give up at this point, of course there is the CUxD document!)
If not yet available, please create a device (28) System Exec! Above that the commands are issued. (No entries are made in CUxD-Exec!)
Creation of a CUxD (40) 16-channel universal control as a switch
(I use a free channel of the remote control of the Shelly EM!)
With each channel of the CUxD device, 1 Shelly 3EM can be mapped.
The settings of the channels:
The Shelly 3EM has two measuring channels to which two transducers can be connected.
Attention !: However, only one relay / switching output is integrated to control an external controls. When creating scenes or actions, the correct channel selection must be observed!
SWITCH|CMD_EXEC: Check mark!
Settings for SWITCH|CMD_SHORT:
Settings for SWITCH|CMD_LONG:
Adapt the IP address of the Shelly 3EM in each case!
This makes the Shelly 3EM ready for use and can be switched on and off. ![]()
____________________________________________________________
The instructions including the scripts and pictures are subject to copyright. Who violates the copyright (for example, images or texts illegally copied and published on other websites), makes itself gem. §§ 106 ff UrhG punishable, can also be warned with costs and must pay damages (§ 97 UrhG).
© 2020 SparkyMaster
