MQTT disconnected
    seit dem letzten Update verbinden sich meine Shellies nicht mehr per MQTT. Irgendeine Idee, was ich tun kann. Es gibt neuere Shellies im gleichen Netzwerk die weiterhin per MQTT Werte verschicken.
    Vorab vielen Dank.
    Gruß, Jens
    Anbei mein Status:
    {"wifi_sta":{"connected":true,"ssid":"xxx","ip":"192.168.xxx.xxx","rssi":-68},"cloud":{"enabled":false,"connected":false},"mqtt":{"connected":false},"time":"","unixtime":0,"serial":1,"has_update":false,"mac":"2CF43268E775","cfg_changed_cnt":0,"actions_stats":{"skipped":0},"rollers":[{"state":"stop","source":"input","power":0.00,"is_valid":true,"safety_switch":false,"overtemperature":false,"stop_reason":"normal","last_direction":"open","current_pos":100,"calibrating":false,"positioning":true}],"meters":[{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0},{"power":0.00,"overpower":0.00,"is_valid":true,"timestamp":0,"counters":[0.000, 0.000, 0.000],"total":0}],"inputs":[{"input":0,"event":"","event_cnt":0},{"input":0,"event":"","event_cnt":0}],"temperature":38.40,"overtemperature":false,"tmp":{"tC":38.40,"tF":101.13, "is_valid":true},"temperature_status":"Normal","update":{"status":"unknown","has_update":false,"new_version":"","old_version":"20230503-095750/v1.13.0-g9aed950"},"ram_total":50720,"ram_free":37216,"fs_size":233681,"fs_free":144576,"voltage":235.23,"uptime":6}
