How much sustain load is the Shelly 1PM supposed to handle?
  • I got a Shelly 1PM installed behind a 15A power point that is used with a Tesla mobile charger. I'm located in Australia so 230V/50Hz country
    Now the mobile charger will draw 15A continuously.
    Despite the Shelly 1PM being rated 16A, it will go into overpower mode within 5 minutes.
    the 1PM is supposed to be rated for 16A, so assuming I don't have a faulty unit it's a rather misleading ratings.
    Has anyone used a Shelly 1PM to monitor such load? if it's a known issue with the 1PM, which shelly would handle 15A continuous draw?
    Thanks in advance.
    Jean-Yves
  • for monitoring you should use a measurement Shelly (EM, 3EM) not an actor, which should switch something ;) .
    My mind.
    they are significantly bigger and can't be installed within an existing GPO though.
    In any case, why rate something 16A if it can't even do 15?
