Script to switch OFF
Hinweis für Entwickler
  • Hello all,
    I just learned about scripting as I'm looking for a solution for an issue I have.
    I want to setup my shelly pro 3 in such a way that if one of the S terminals gets a pulse, the corresponding output is set to OFF.
    I need this so that I can switch on lights with my physical momentary switch in my house but also use the Shelly pro 3 with Home Assistant/Google automations.
    The problem now is that if I switch on my light with a shelly output I cannot turn it off with the momentary switch unless I first use a HA/Google voice command or similar.
    I want to add a wire from the momentary switch in parallel to the shelly S terminals so that if a pulse is given to that terminal, the shelly knows it has to turn OFF no matter what its current state is.
    Thank you for the help!
