Shelly right or wrong behaviour?
  • Hello, My name is Juan, I am new in the forum and I use Openhab and Sonoff switches with Tasmota, untill I discover Shelly. They seems to bee fantastics.
    I move to a new home and I wanted to integrate shelly in the wall switches. I made some test with MQTT and work fantastic, only I have an issue that I do not know if this is the normal behaviour or not.
    - I turn on - off from the Openhab, lights on/off as normal, and I can see the status in the screen.
    - I turn on - off from the ext switch, works fine and I can see the status on the screen
    - I switch ON from the wall, and then switch OFF from the APP. If I go again to the wall switch, does not turn ON again. I have to switch 2 times.
    This behaviour happen independently if the light is ON or OFF. And if I switch first from the Openhab and then from the wall, happened the same. ON from Openhab, then I go to the wall switch, and when I switch, nothing happen, I have to switch again to turn OFF.
    I hoped that when you switch ON/OFF from the wall and then from the app, is consistent and react as a Switch independently of there is tension or not.
    I followed the wiring from the manual, like this:
    Is this the normal behaviour, or I am missing some configuration?
    With sonoff, I could connect external switch to the GPIO-PIN programing, and worked fine (it was like an Open C. Close C.)
    Thank you for your feedbacks!
    416-ausschaltung-png
    Einmal editiert, zuletzt von Steep#Disk#5722 (15. Februar 2020 um 19:51)
    Hello grhosso
    WELLCOME TO THE FORUM
    You need to set up the button type to "edge". Then it should work as you expect.
    Grüße Bernd
    Mein "Smarthome":
  • I cannot do it. I get an error :/
    I have updated the firmware, but it does not work.
  • Hey, I found the solution.
    I selected "POWER ON DEFAULT MODE" = Restore and now is working.
    Thanks.
