Shelly PRO 3EM Not excluding all 3 fase from total consumption
  • Hello is it a know problem or on my end
    My Shelly PRO 3EM is not excluding all 3 Phase from total consumption.
    Its seems its only excluding Phase 1 and not the rest.
    I dont want the vallue from this meter included at the total
    Bechose its a backtest of what is consumed.
    example:
    When everything is running and all rooms consumption ends up to 100w
    the backtest sill then schow the consumption loss from all the schelly 120w total
    Data info
    current:
    Now what i get at the top in current is correct power: 100w
    excluding 120w
    all those are fine
    overall:
    here is the problem
    total day consumption = 5kwh excluding 1.2
    that 1.2kwh excluded is incorrect when you then go and look at the Shelly pro 3em the total there is 3.25kwh (phase A 1.2kwh, phase B 500wh, phase C 1.6kwh)
    anny help is welcome
    thanks
    Einmal editiert, zuletzt von Clipson Plextorfield (19. April 2023 um 12:47) aus folgendem Grund: not compleet info
