Shelly Timer stops after some days of runtime --> why?
Hinweis für Entwickler
  • Hi all,
    I am using a Shelly Plus 1 running a script I wrote that is triggered by a timer. Everything works perfectly, my function is executed once every 10 minutes with the call
    Timer.set(1000*60*10, true, checkFloorHeaterConditions, null);
    My problem with this now is that unfortunately the script only runs for a few days and then at some point it just stops.
    Is there an internal counter or similar for the timers, so that the max. number of executions is limited? I would say that the script runs for 3-4 days before it is stopped, which would be about 4 x 24 x 6 = 576 executions. Maybe there is a magic limit at 2^9=512 or something? I have no idea, but maybe someone of you?
    Thanks
    Sven
  • Hi Sven,
    a ticket to Allterco can bring the answer.
    Please let us know, what Allterco says.
  • Quick and dirty. Nightly reboot a possible solution?
  • Hey you two,
    thank you very much for your input!
    ostfriese : You have some very simple but however sophisticated ideas, I would not have thought about these by myself, geat!
    I will give them a try and also have some other ideas. If these won't lead to success, I will create a ticket for Allterco.
    Anyway I will give you feedback.
    Best regards
    Sven
