Topic with LWT in script
Hinweis für Entwickler
  • Hi,
    Is there a way with a script to create a topic with LWT.
    This is to monitor a Bluetooth module (Nut) which gives its presence every minute.
  • Messages can have the retain flag but I'm not sure it's possible to create a special retain topic.
    https://shelly-api-docs.shelly.cloud/gen2/Scripts/S…geFeatures#mqtt
    MQTT.publish(topic, message, qos, retain)
    if true the message is retained by the broker and delivered when subscribers are activated. Optional, default is false
    maybe just
    MQTT.publish(topic + 'online', 'false', 0, true);
