How do we set up the door, so I have the following
relay 1 protection setting I take it is set from http://YOUR IP ADDRESS /#/switch/0/settings/protections
relay 2 protection setting I take it is set from http://YOUR IP ADDRESS /#/switch/1/settings/protections
the web button interfaces button 0 Open/Close relay0/relay1
the web button interfaces button 1 Emergency Stop
Plus interlock relay, so relay 0 + 1 can not be on at the same time.
Finally, the web interface in Shelly 2.5 roller setup is easy and well documented.
"Shelly2.5 can operate in two distinct device modes: Relay and
Roller Shutter. Devices are initially programmed to work in Relay mode. The operating mode of Shelly2.5 can be set via the /settings"
