External Temperature sensor ?
  • Is there any way to add an external temperature sensor to the Pro 1PM ?
    Not that I am aware of any add-on's for the pro modules. However I have the need from a temperature sensor as well and have just purchased the Shelly Plus Addon module. This clips onto the shelly plus modules and extends their capabilities. Including the Shelly 1PM plus which is also a 16A relay similar in capability to its bigger brother the Shelly Pro 1PM.
    The Add on Module has the ability to run 3 data inputs (Vcc Data GND). So you could have 3 temperature sensors or a mix of temperature humidity and light sensors all from the one Shelly item.
    As its a smaller formfactor item if you wanted that mounted in a consumer unit (the Shelly Pro's are Din rail mounted so I have assume your requirement here). you'll need to also download the thingy-verse 3d print of the DIN rail mount for the shelly Plus.
    I hope that helps.
    Take care D
  • duncan.gardiner  @66er : Thanks for the reply's.
    I already have the add on module , but I was after a way of having a LAN connected device as the location of the required control is in my greenhouse and the WiFi drops out to my Sonoff THElite that controls my greenhouse heater (via Home Assistant).
    It looks like I will have to go the ESPhome route with an Olimex ESP32 POE....
  • but I was after a way of having a LAN connected device as the location of the required control is in my greenhouse and the WiFi drops out to my Sonoff THElite that controls my greenhouse heater (via Home Assistant).
    Hi I had the same issue in my Garage. I live in Portugal so all the homes here are concrete block walls, which Wi-Fi struggles to pass through. In rooms I need Wi-Fi I am using POE driven access points (I use the Unifi eco system, either light ceiling mounted, or AC in Wall mounted where I have LAN sockets available.
    I am using a Shelly 3 Pro in my pool house for the same reasons you've describe. but I could have also added a Unifi external access point out there which would have given me better Wi-Fi coverage around the pool as well as provide a link to my shelly.
    Many ways to skin a cat I guess.
    Take care D
