  • Hi there,
    We need some help for Fleet Management. Probably we found Memory Leak.
    Our Configuration is 6pcs Shelly Pro 3EM with custom firmware which is reading data on every 1 second. Devices are not linked with Shelly Cloud - only with Fleet Management.
    The problem is on every 12 hour - Memory Is getting Full and the app is terminate by it self. Right now we use Cron process which restart the app if app is closed.
    Can someone help here @Kalin Krastev ?
  • Hi! Implementing a custom firmware for such frequent data readings might be causing the memory overload. To resolve this, I'd recommend optimizing the firmware or adjusting the data reading frequency to alleviate the memory strain. If you need assistance with fleet management app development or debugging, I'd be glad to lend a hand.
