MQTT Topics list
  • Dear Shelly Support Team
    I'm trying to get power values out of my Shelly PM 3EM by MQTT. For me it look like the topics structure is different from the 3EM.
    With the command : mosquitto_sub -h <IP> -p 1883 -v -t shellypowermeter/status/em:0/#
    I get the return:
    shellypowermeter/status/em:0 {"id":0,"a_current":0.132,"a_voltage":236.0,"a_act_power":3.9,"a_aprt_power":31.0,"a_pf":-0.53,"b_current":0.594,"b_voltage":236.4,"b_act_power":45.4,"b_aprt_power":140.3,"b_pf":-0.61,"c_current":0.368,"c_voltage":237.8,"c_act_power":54.3,"c_aprt_power":87.5,"c_pf":-0.72,"n_current":null,"total_current":1.094,"total_act_power":103.610,"total_aprt_power":258.799, "user_calibrated_phase":[]}
    But no return with: mosquitto_sub -h <IP> -p 1883 -v -t shellypowermeter/status/em:0/total_acpower
    What's my fault?
    Thank you in advance.
    Mr.Dilbert
  • Well, in the JSON output above one can see "total_act_power":103.610 so I assume it should be possible to read this data with the topic shellypowermeter/status/em:0/total_act_power.
    Basically I want to read the current power consumption. Any ideas to get this by MQTT?
  • Every minute the shelly pro 3EM publish the sum of act energy and act returned energy to the emdata topic:
  • Same issue. Ok emdata provide the sum of some energy data but what if I want the a_current, for example? There are not specific topics for each variable? Only a global topic with a JSON as answer?
