Cloud API Getting EM CSV file with power consumption
  • Is there a way to download a CVS file from EM? I can only get the status when using:
    curl -X POST https://<server_uri>/device/status -d "id=<device_id>&auth_key=<auth_key>"
    but no info on how to get other parameters or csv
    curl -OJ -X POST -d "add_keys=true&ts=1677625200&end_ts=1679698800" https://<server_uri>/emdata/0/data.csv -d "id=>device_id>&auth_key=<auth_key>"
    I get a file with "{"isok":false,"errors":{"404":"Requested method was not found"}}"
  • Hi, I have exactly the same question : is there a way to get the power data recorded for a specific day (or day range) via the cloud API? (even is the result is return as JSON and not CSV file)
    Thanks in advance :)
    Edit: Removed full quote by Mod
    Einmal editiert, zuletzt von Devil (6. Juli 2023 um 14:30)
  • Abelblublight
    of course you get an error, your code is: "https://<server_uri>/emdata/0/data.csv"
    the EM has no file called "data.csv", neither does it have a folder named "/emdata/"!
    correct would be: "http://<shelly_uri>/emeter/0/em_data.csv"
    type it into your browser's address field and hit enter, browser will ask you where to save the file.
    Besides, i thought shellys don't work with https, only http?
