Reading input and temperature in a script
Hinweis für Entwickler
  • I want to read the status of my inputs and the temperature of my DS18B20 sensor on my add-on. Can anyone provide
    a code snippet to do this?
    The code snippet supplied by Shelly does show how to get the input status but via a callback which only gets called on a change.
    I would like to just read the status.
    I cant work out how read the temperature at all!
  • Hi and welcome to the forum. :)
    What kind of script do ask for? Shelly-scripting or script for a automation system like ioBroker?
  • Here's a quick example
    just for clarification: it is mandatory to have some basic javscript skills in order to work with Shelly mJS, all functions are documented here:
    https://shelly-api-docs.shelly.cloud/gen2/Scripts/S…anguageFeatures
  • Hello!
    If you want to read the temperature from the DS18b20 sensor on the Shelly AddOn, you should call something like this:
    Shelly.call(
        "temperature.getStatus",
        { id: 100 },
        function (response) {
            MQTT.publish("hello/world", JSON.stringify(response), 0, false);
        null
  • Could you show an example of reading the temp/hunifity, calculate the dew point and activate the power outlet if dew point is below x degrees?
