Output data from script to Shelly app?
Hinweis für Entwickler
  • Hello, is it possible to display data from a script in the Shelly app?
    I would like to do some calculations in a script, and I would then like to show the result of those calculations in the Shelly app, and also trigger a notification in the app if the result is outside a certain range. Is there a way to do that?
    The script will run on a Shelly Plus 1PM.
    Any help is appreciated, Thank you!
  • Hey everybody,
    i also would appriciate this feature.
    I have an additional question: Is it possible to trigger a script from the Shelly app?
    Thanks for any advice.
  • I have an additional question: Is it possible to trigger a script from the Shelly app?
    Currently not but I believe this will be implemented sooner or later.
