Shelly +1PM device temp into Home Assistant?
  • Hi everyone – I'd like to be able to monitor the Device Temp of my Shelly +1PM in Home Assistant.
    I know the 'Shelly Scanner' app can get device temp info, and I'm looking at the API documentation (https://shelly-api-docs.shelly.cloud/gen2/Devices/ShellyPlus1PM) but the only reference I can see regarding Device Temp requires an MQTT connection (something I'd prefer to avoid using, for the time being).
    So! How can I get realtime Device Temp info? Is it available as an RPC url? Thanks!
  • And for anyone else reading this thread, a typical Home Assistant entry in the configuration.yaml for parsing JSON / REST data would look like this:
    sensor:
      - platform: rest
        resource: http://192.168.xxx.zzz/rpc/Shelly.GetStatus
        unit_of_measurement: "C"
        method: GET
        name: "Shelly Switch Device Temperature"
        value_template: "{{ value_json['switch:0']['temperature']['tC'] }}"
        force_update: true
    And FWIW one way to make the JSON payload easier to read, paste everything here:
    https://http//json.parser.online.fr/
    3 Mal editiert, zuletzt von disuye (16. März 2023 um 19:03)
  • Hello, has the code “value_template” changed, unfortunately it doesn’t work, can someone help me?
    (Shelly Plus 1PM SNSW-001P16EU)
      - platform: rest
        resource: http://192.168.XXX.XXX/rpc/Shelly.GetStatus
        unit_of_measurement: "°C"
        method: GET
        name: "Shelly PV-Anlage Temperature"
        unique_id: "ShellyPVAnlageTemperature"
        force_update: true
    Result:
