Script for Switching Multiple Shelly Devices off/on and Enable/Disable Schedule
Hinweis für Entwickler
  • Hi,
    Looking for some help in creating a script which switches off a number of Shelly devices and disables schedules on certain device (so they don't turn back on). Don't really know where to start ?( .
    Scenario is I have a Shelly Addon which takes an input from an alarm system relay - when the alarm is armed, the relay (dry contact) closes. I want to switch off a series of Shelly devices (all on static IP addresses) and also disable the schedules set on some of these devices. When the the alarm is disarmed and the relay opens I want to switch the devices back on and enable the schedules again. I already have the input to the Addon working and can send basic on/off commands by hitting the url of a device but I want a more elegant solution which will switch off/on multiple devices.
    Can anyone help with the basics for this script?
  • Take a look here:
    Harry Plotter
    16. Oktober 2023 um 09:23
  • Dieses Thema enthält 27 weitere Beiträge, die nur für registrierte Benutzer sichtbar sind.
